  1. In Maestro it gives you the function to put numerous languages and subtitles to a movie but I can't seem to find how to make a specific button to change the language/subtitles, could someone please tell me how to do this or tell me where to find a guide.
    Thx
    DDI
  2. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    ( I will give you the answer from memory, so I hope that there will be no mistakes in my comment)
    If you want to link a button to a subtitle or audio stream, you cannot pick a target like you do with (for example) chapters.
    At the bottom of a menu you can specify which color a button should have, or to which other button you'll jump when you press up or down on your remote control. At the right side you can check or uncheck to which subtitle or language stream this button will be linked. That's it.
    The Dutchman
