Hi,
I am trying to encode a AVI and MP3 file togetter I am using TMPGEnc. I select the Video file with no probs, but when I select the Audio file (MP3 part) I get an error message "Can not open or unsupported"
I went to the Environmental setting\Audio Engine and put an External Program for the MPEG-1 Audio Layer 3 encoder. But still get the same error message.
Do I need some sort of Plugin to get this to work?
Bscull
Results 1 to 12 of 12
I was able to encode an AVI video file with a MP3 audio file using TMPGEnc v2.52 with no problem. Maybe later versions won't work?
Chas -
VCD/SVCD doesn't use MP3 for it's audio. VCD/SVCD uses MPEG-I Audio Layer-II. :P
puertorican138
What I meant to say was, I was able to use an AVI video file with a MP3 audio file using TMPGEnc v2.52 to make a MPEG file with no problem. I believe that's what bscull was trying to do.
Chas -
My bad for mis-understanding you.Originally Posted by Megahurts
Video Browse > AVI
Audio Browse > AVI (For audio)
Video Browse > AVI
Audio Browse > WAV
but
Video Browse > AVI
Audio Browse > MP3 Wont work !
Thats what the guy is saying, well at leased thats how I read it. -
KingJohn
Audio Browse > MP3 works for me. I'm curious why it does'nt work for you. What happens when you try to load a file? Do you get a error message as the original poster? What version of TMPGEnc are you using?
Chas -
Can we use MPEG-Audio Layer3(MP3) for audio part?
TMPGEnc does not include MP3 encoder. You can use external encoder
To encode MPEG-1 Audio Layer-III (what we call MP3) which is not supported by TMPGEnc solely, specifies if TMPGEnc Plus use external MPEG-1 Audio Layer-III encoder or not.
MPEG-1 Audio Layer II encoder
Selects built-in engine or external encoder to encode MPEG-1 Audio Layer-II.
Use built-in engine
Uses built-in encoder to encode MPEG-1 Audio Layer-II.
External program
Uses external encoder to encode MPEG-1 Audio Layer-II. Press "Browse" to specify the external encoder.
As external encoder for MPEG-1 Audio Layer-II , MAENC(maenc.exe), tooLAME(tooLAME.exe), SCMPX(SCMPX.exe) can be used. TMPGEnc Plus does not warrant to work with other encoder than encoders above.
MPEG-1 Audio Layer III encoder
Do not use
Does not encode MPEG-1 Audio Layer-III.. In this case, [ MPEG-1 Audio Layer III ] option does not appear at "audio" tab in MPEG setting.
External program
Uses external program to encode MPEG-1 Audio Layer-III. By "Browse" button, you can specify the external program file name.
As external encoder for MPEG-1 Audio Layer-III , MAENC(maenc.exe), tooLAME(tooLAME.exe), SCMPX(SCMPX.exe) can be used. TMPGEnc Plus does not warrant to work with other encoder than encoders above.
More
TMPGEnc Plus Version 2.510 (2.510.94.157)
- Fixed: In the Environmental setting window, General tab, checking Enable multiplex with... and chosing audio file other than mp1, mp2 or mp3 format would raise an error when starting to encode.
- Fixed: In the MPEG setting dialog window, GOP structure tab, when Detect Scene Change and Force picture type setting were both selected, closing the dialog window and re-open it would clear the Force picture type setting checkmark.
- Fixed: In the MPEG setting dialog window, System tab, chosing MPEG-1 Video-CD (non-standard) would in fact select the MPEG-1 Video-CD setting.
So depending on what vertion you have, what you have installed, all standard defaults would not use MP3 -
As already indicated, the simplest way is to convert your .mp3 to .wav, and then it will work.
XVID/mp3 file wont open in TMPGENc express
By efiste2 in forum Video ConversionReplies: 5Last Post: 14th Jan 2010, 17:16 -
Mp3 tags for Zune problem
By ultraman36 in forum AudioReplies: 1Last Post: 14th Mar 2009, 16:30 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
XVID AC3 TO MP3 Conversion problem help!
By sere83 in forum Video ConversionReplies: 4Last Post: 3rd Nov 2007, 15:55 -
MP3 Bitrate problem
By efiste2 in forum AudioReplies: 8Last Post: 25th Sep 2007, 20:59
