If I convert a VCD "dat" file into "mpeg" format using TMPEGEnc, it takes 1 hour, but only 5 minutes if done through VCDGear. Is there something extra TMPEGEnc doing or for that matter VCDGear not doing? Or I am making some mistake?![]()
If you do it in TMPGEnc you are actually reencoding the film, big no-no reencoding=quality loss. VCD gear just rewrites the file header and changes the file from dat to mpg. This is the method you should be using.
You don't need to convert it to anything, it is already an mpeg 1, most authoring programs will accept the file "As is" it can be loaded into vdub with (*.*) or used with TMPGEnc (*.*) if your having problems loading into any programs just rename it .mpgOriginally Posted by Chikoo
If you want to strip the vcd headers, use TMPGEnc Split&Merge and just save out another copy as "MPEG 1 Video CD"
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
authoring PAL DVD using "mpeg-4 avc" NTSC 1280x720 VOB files
By ah76 in forum Authoring (Blu-ray)Replies: 14Last Post: 31st Oct 2009, 10:31 -
"Washed out" mpeg from AVI conversion
By gg2004 in forum Video ConversionReplies: 4Last Post: 15th Sep 2007, 03:50 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 22:55
