whats the fastest and most efficient way of converting WMV files to MPG1? what are the freeware tools to use? any detailed instructions? thanks!![]()
TMPGEnc
Guide shows AVI, but WMV will also work
http://www.vcdhelp.com/forum/userguides/135238.php -
even for the TMPGenc freeware tool (not the PRO version)?Originally Posted by KingJohn
Yep, should be no diffrent.
M$ WMV V7 (WMV 1)+(WMV 2) PCM Audio
WMV-V1-2.zip
sorry off topic, but.. that's a nice download icon!!!Originally Posted by KingJohn
what is this file all about? tutorial? codec? pls advise.Originally Posted by KingJohn
These are test files made with the popular codecs, the idea is that you download each one and test your system, if you find one that wont work, you only need to look at its name to know what you have missing.
In this example "M$ WMV V7 (WMV 1)+(WMV 2) PCM Audio "
Those are .wmv movie clips made with the Microsoft codec WMV 1 and WMV 2, with PCM (Uncompressed) audio
http://www.vcdhelp.com/forum/userguides/135217.php
Burning several mpg files straight to a DVD compliant disk...
By vonsworld in forum Authoring (DVD)Replies: 2Last Post: 5th Dec 2010, 07:25 -
VCD MPG1 file to CD Question
By Excelsior123 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 22nd May 2008, 20:14 -
WMV to DVD compliant MPEG2 - TDA3 or DVD Maker - what is the right way?
By MagicSparky in forum Video ConversionReplies: 5Last Post: 23rd Aug 2007, 13:27 -
.flv to .wmv or wmv. to mpg
By LITEONDVD in forum Video ConversionReplies: 5Last Post: 29th Jul 2007, 19:02 -
Best way to convert avi to MPG DVD Compliant(highest quality)
By andre477 in forum Video ConversionReplies: 19Last Post: 25th May 2007, 05:59
