I've ripped the 'Panic Room' DVD successfully using DVDDecrypter, and want to split the main title between 2 DVD-Rs (it's 5.3Gb, so won't fit, even if I remove languages etc). This usually works fine - but for some reason there is no 'layer br.' marked on the program chain. Of course, I can just select my own, but does anyone know why it doesn't show up in IFOEdit?
cheers,
MArk.
Results 1 to 1 of 1
Spliting DL-DVD at layer break point
By smartel in forum Newbie / General discussionsReplies: 9Last Post: 27th Mar 2012, 12:19 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 13:26 -
Placing a chapter point at layer break spot?
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 12th Aug 2008, 19:02 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 12:27
