I have some Xvid fles, they are very high quality, but there is no sound when playing them on media player, and when using Tmpgenc. I do have a CODEC for Xvid, and do have some working Xvid files.
Can someone advise me, as I have tried everything.
BBB AAA X X
B B A A X X
BBB AAAAA XX
B B A A X X
B B A A X X
BBBB A A X X -
I think your movie have AC3 sound so you must have the codec for it.
Try first uninstall all your codecs then install this it and see if it works:
http://www.quellicheilpc.it/quelli02/download.php?op=viewdownload&cid=77
It´s a italian site but you will find it.
And if that don´t work then try this:
Uninstalled all DivX codecs and xvid codecs,(Nimo Pack etc.)
You can then install xvid codecs from here:
http://www.divx-digest.com/software/xvid.html
Then install all DivX codecs separat (Not from Nimo).
http://www.divx-digest.com/software/divxcodec.html
After that install Nimo Pack but uncheck all divx codecs and the xvid codec and also uncheck a direct show filter which is Ffdshow DirectShow
Install Nimo from here:
http://www.btinternet.com/~nimosiro/
Now all should work fine!
By the way,AC3 comes with the Nimo Pack -
Thanks for that.
Now I have a different problem.
I can now play Xvid with sound no problem, but when I encoded the file to SVCD, the SVCD file had no sound!!
Any idea why?? I am using Tmpgenc with standard SVCD(PAL) template.
Bax.
BBB AAA X X
B B A A X X
BBB AAAAA XX
B B A A X X
B B A A X X
BBBB A A X X -
Try this for AC3 (The best)Originally Posted by bax2097
http://www.moonlight.co.il/download.htm
Moonlight Odio Dekoda DirectShow® filter, binary (71,855 bytes, ZIP)
HTTP Download, U.S. Primary (it is recasting)
HTTP Download, U.S. Secondary <<<<<<
HTTP Download, Russia
Test your system with these
http://www.vcdhelp.com/forum/userguides/135217.php
If you need a codec, don't install trialwear or spywear, only full versions -
The software you suggested is for Mpeg only. I am using Xvid->Mpeg
BBB AAA X X
B B A A X X
BBB AAAAA XX
B B A A X X
B B A A X X
BBBB A A X X -
Universal AC-3/MPEG Audio (Layer 1/2/3) Decoder
Moonlight Odio Dekoda DirectShow (R) filter enables software-only
decoding of MPEG-1/2/2.5 Layer I, II and III (also known as mp3),
Dolby(R) AC-3 and LPCM audio streams. The filter automatically detects proper
stream format and choses corresponding decoder thus allowing seamless
switching from MPEG audio to AC-3 (even during playback) and vice versa, and
between various MPEG encoding modes
Best way to batch convert xvid/avi files to mkv/x264 files?
By gaikokujinkyofusho in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 06:31 -
repair xvid files
By greendesert in forum Software PlayingReplies: 5Last Post: 17th Dec 2011, 22:44 -
XviD undersized files?
By Mdoodm1000 in forum Video ConversionReplies: 7Last Post: 24th May 2010, 21:22 -
Certain XviD files won't play
By Towin in forum Software PlayingReplies: 2Last Post: 10th Dec 2009, 18:01 -
2 xvid files 2 srt files
By blot in forum Video ConversionReplies: 4Last Post: 25th Sep 2007, 10:34
