I was working on my review fir ShowBiz and on their web site they mentioned somthing called "Smart Rendering". What it means is if you import mpeg-2 that is same format as your otput file, they will not re-encode it. It works fine for files that were produced by ShowBiz but not by my capture card or for example Pinnacle Studo 8. Does anybody know why ?
The only difference that I see when looking on properties in VideoStudio6 is that from my capture card media type is
"MPEG-2 NTSC, Field B"
and from ShowBiz it is just
"MPEG-2 NTSC"
all the other properties are same.
Results 1 to 9 of 9
Pinnacle Studio 8 and DV home video editing (ver.9 already home)
It could be your video GOP is not within specs.Also is the audio samplerate 44.1 or 48khz(MPEG-2 is 44.1 and DVD is 48khz).
48.
How do I check GOP ?Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
I just tested Showbiz and it will smart render a VCD file,but when I tried several MPEG-2 files it rendered them all.
I guess it isn't so smart after all. -
It is smart only when mpeg2 was produced by ShowBiz.... Maybe some kind of self-protection so you won't use encoder from other company
How can you tell if it is/is not re-rendering? So if I add a bunch of clips made in Showbiz that are mpeg2 and add some avi's it will only render the avi's in the movie but not the Mpeg2 parts?
You can see it by speed how that part is processed. Also by message, but I don't remember what it is exactly.... I was testing only 1 mpeg file.
donpedro, I have 2 Showbiz questions. Can you auther a dvd through Showbiz with a menu and chapter buttons? I have been using showbiz for all my videos and when I save as mpeg1 it chops off the last couple of seconds but not on mpeg2 then it is fine ,have you noticed this?
No. ShowBiz is only editing tool. In my case it is part of MyDVD package that came with Sony burner. Follow link below to see what it can do.
Encodin VFR usin x264.exe?
By The Scenes in forum Newbie / General discussionsReplies: 0Last Post: 17th Oct 2011, 20:36 -
ArcSoft Showbiz DVD 2 Smart Rendering
By zulubase in forum Newbie / General discussionsReplies: 0Last Post: 28th Oct 2009, 21:12 -
Transitions make static in Arcsoft Showbiz MPEG2
By Canopus Smoker in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2008, 22:10 -
arcsoft video impression
By skybird in forum Newbie / General discussionsReplies: 0Last Post: 19th Sep 2007, 13:41 -
ArcSoft ShowBiz Audio Problem
By KenOBrien in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2007, 06:29
