Hi, I have been making vcd and svcd movies now for about a year, and I have downloaded the samples and viewed them. I have achieved quality similar to the quality in the vcd sample, but I have not even come close to the svcd sample quality. Can anyone tell me what the specs are for that sample because I would love to get that kind of quality. If it has to do with the filters used when encoding please let me know which ones. Thanks
It's all about your source and encoding options. For best results you need/want an excellent source (eg. DVD rip).
As for encoding. Either set the bitrate to the max supported by your standalone and/or use multipass VBR encoding. For example, I've found that when backing up DVDs if I use CCE to encode with 3pass VBR (300, 2000, 2700) I get damn near DVD quaility encodes.
Join .avi files, different video sample rates
By -mm- in forum EditingReplies: 22Last Post: 12th Oct 2014, 07:46 -
Sample Blu ray, m2ts, mts files
By pepegot1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 8th Jan 2011, 16:15 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 11:26 -
Viewing tests and sample files
By Movie-Maker in forum Newbie / General discussionsReplies: 5Last Post: 6th Sep 2008, 13:56 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56
