I've burned bin and cue file several times on my computer with windows me, but I cant find one program that will work on my computer with windows xp. I tried cdrwin, but get this message: NO CDROM recording device was found on the SCSI or IDE bus. What does that mean and how can I fix it, or are there any cue/ bin burning programs that work with windows xp?
Results 1 to 11 of 11
I use CDRWin 3 on Xp no probs, If i remember right i think i had to Make sure that my writer was in PIO mode And not DMA before CDRwin would pick it up Im not sure cos it was ages ago.
I think it says summat on there website.
But if all else fails you can use VCDgear to turn the Bin image back into a Mpeg. -
Ya, I know how to make mpegs, I just wanted to burn it how it was to keep the chapters.
Nero sucks in genreal (unless you want to burn PC/mode1 data or audio files). CDRWin, CDRDAO (w/ gui: TSCV, VCD Easy, Xduplicator), etc. all work.
Do you have an ASPI layer installed in winXP? Because it doesn't come standard with one
If not, d/load and install and see if that fixes the problem.
when I downloaded cdrwin it said it came with aspi drivers I think. I dont know if that is the same as layers, but I still got that error message when I tried burning.
tried the forceaspi drivers?
tried with vcdeasy, http://www.vcdhelp.com/forum/userguides/133785.php ? -
cdrwin 3.9x and prassi both burn bin/cue files fine on XP .. so does nero but Not perfect if source is multi track cue file (at least i had some problems) ..
to be honest with you, I've had no problems with Nero as long as I don't use their fancy functions. I load up the Bin/Cues with Daemon Tools as a virtual CD and then use "CD Copy" in Nero "on the fly" and can burn at as fast a speed as I want. There is no problem with mode 1 or mode 2 file configurations. Give this a try if you want. Just do a search for Daemon Tools if you don't have it. It will come right up in google.
try fireburner
do a search on download.com
great little program that works great in xp and never gave an error yet and i have burned 1000's of disks
best of luck
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
