Unrecognized exception!
line 6
is what im getting when attempting to use the script below...
LoadPlugin("C:\AviSynthPlugins\MPEG2DEC.dll")
LoadPlugin("C:\AviSynthPlugins\legalclip.dll")
LoadPlugin("C:\AviSynthPlugins\sampler.dll")
LoadPlugin("C:\AviSynthPlugins\convolution3d.dll")
LoadPlugin("C:\AviSynthPlugins\dustv4.dll")
Mpeg2Source("C:\AviSynthPlugins\ct.d2v")
legalclip()
GripCrop( 352, 240, overscan=1)
GripSize()
Gripborders()
faerydust()
Convolution3d(preset="movieLQ")
legalclip()
Sampler()
Sampler(length=24)
this is why i dont like avisynth... anyway... trying to learn
could it be because of the d2v file?
when i put the vob there, and changed the script for it, i got
MPEG2Source: couldn't open file
line 6
Results 1 to 15 of 15
I don't recall off the top of my head if AVISynth is case-sensitive, but if it is, you might try changing "Mpeg2Source" to "mpeg2source". By comparison with one of my scripts, I can't see any other reason why that line would be resulting in an exception.
No converting to lower case didnt work either
i also tried running the d2v file thru VFAPI to make a psuedo avi
got the ...
line 6
I assume of course the .d2v file is actually at the specified path (e.g. in the same directory as all the plugins). Sometimes this kind of thing is a cut-and-paste error but I kind of doubt it.
I would probably just do a step-by-step debugging. Start with a minimal script (just the mpeg2dec plugin and the .d2v load command). Then start adding the other lines in one by one to see if it's actually getting confused somewhere else and giving an erroneous error message (these things amazingly do happen: errors in the error message - great ain't it). -
k.. narrowed it down to
mpeg2source("C:\AviSynthPlugins\ct.d2v")
still getting the same "Unrecognized exception! " error
and yea, the d2v file is in the same directory
by the way, thanks for helping me out here, hopefully we can get it -
Have you upgraded to a newer version of Avisynth recently? Or changed the version of the plugin? Perhaps there's an incompatibility in there...
Do you have other scripts are working? Oh, and how is the unrecognized exception being reported? -
about a month or 2 agoOriginally Posted by kinneera
worked on a couple other scripts.. tho im not sure if it ever worked with mpeg2...
when i load into tmpgenc, or wmp, it will display the errorOh, and how is the unrecognized exception being reported?
im going to attempt to update my verison of avisynth to see if that helps
i'll let you know.. let me know if you can think of anything else -
Edit... spoke too soon
installed a program called AMVapp
from
http://www.animemusicvideos.org/guides/avtech/amvapp.html
now, it wont give me an error, it will just sit there and "load" forever..
both WMP and TMPGenc... tried waiting.. but ended task on them after about 2 min and using 2GB of VMem
ugh
this sucks -
Did you make your d2v with dvd2avi 1.7?
Have you used 'Faery Dust' before without any problem? -
YesOriginally Posted by pyst
Right now i cant even get it to work with just the mpeg2source lineHave you used 'Faery Dust' before without any problem? -
I should have asked if you used 1.77.3 and if so it might be worthwhile trying an earlier version. 1.77.3 d2vs were a problem for me and 1.76 d2vs work ok.
Hi johneboy,Originally Posted by johneboy
First, use DVD2AVI 1.76. Don't use version 1.77.x
Next, change the order of your filters like this, and update to the new Dustv5:
The difference in speed from SpaceDust to FaeryDust is huge. Use FaeryDust only if your source is a noisy DVD. You may also want to try TemporalCleaner instead of C3dCode:LoadPlugin("C:\AviSynthPlugins\MPEG2DEC.dll") LoadPlugin("C:\AviSynthPlugins\legalclip.dll") LoadPlugin("C:\AviSynthPlugins\sampler.dll") LoadPlugin("C:\AviSynthPlugins\convolution3d.dll") LoadPlugin("C:\AviSynthPlugins\dustv5.dll") Mpeg2Source("C:\AviSynthPlugins\ct.d2v") LegalClip() GripCrop( 352, 240, overscan=1) GripSize() Spacedust() Convolution3d(preset="movieLQ") Gripborders() LegalClip() Sampler(length=24)
-kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
Thanks Kwag
Since i got my new puter, i haven't had an issue with the avisynth scripts anymore...
Also since the release of the new DVD2ONE app... DVD-R just got a WHOLE lot easier, so im going to now go back to playing with VCDs..
Now that avisynth scripts work, ima try to get the most out of your new KVCD templates
Should i use and avisynth script for Dv ?
By smartel in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2012, 09:29 -
Need Help with My AviSynth Script
By Enkidu in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2011, 22:37 -
Avisynth Script Help
By jamhat in forum Video ConversionReplies: 2Last Post: 29th Nov 2009, 07:13 -
Avisynth script
By daz2712 in forum Video ConversionReplies: 2Last Post: 19th Aug 2009, 12:08 -
avisynth script
By magenta2007 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 25th Sep 2007, 12:29
