  1. Here's my problem! Before I recovered my computer and reinstalled Nero I would try to burn a DVD-video and get the reallocation error, and it would tell me about it and I could still burn and they always came out ok. Now that I have reinstalled Nero when I try to burn it just says reallocation failed and spits my black disc out. If I change it to DVD-rom UDF/ISO it will burn fine.
    I know I should just do it that way and not worry about it, but I am just wondering if there is a setting that I can change or something so that it will prompt me of this problem but let me bypass it. I can't figure out what is different now from before.
    Thanks in advance for your time and help.
  2. I used to get that message about the "reallocation of files failed" constantly but I found a good fix for it. I load up IFOEdit and open up one at a time the VIDEO_TS.IFO and VTS_xx_x.IFO and click on GET VTS Sectors for each one. That usually fixes the problem and then Nero will accept the files.
    Jcuervo811
  3. I am having the same issues with reallocation errors. I did this fix too, but it didn't make the error message go away. (The latest version of IfoEdit fixes all the ifo files when you click on GET VTS SECTOR button just once.) I even followed the fix of changing the value of the end sector by -1, but that didn't work either.
    My test disc burned fine and played fine in both PC and stand alone player though. I'm wondering if I should just ignore the error and burn anyway?
    Dec 2003
    Florida, USA
    What exactlly does 'Get VTS Sectors' do?
    Adam
    DVD Decrypter>DVDShrink>CopyToDVD
  5. After trying all the different fixes suggested, seems like buring in UDF instead of DVD-Video is the only way to bypass the error message.
    What's the difference between selecting UDF only and UDF/ISO combo though? Anybody knows?
    Spiffy
  6. @AdamRA4
    Get VTS Sectors explained.
    @fishyboy1
    Current DVD Shrink does not do this anymore but try using 3.0 Beta 5 on all your IFOs separately. If it detects a problem with your titleset, then that's probably the one giving you the reallocation problems. If so, do a mock strip in IfoEdit, which is strip but keep everything in VOB Extras.
    Read this thread for explanation for troubleshooting method above.
  7. DVD Shrink is the way to go!
    When having Nero allocation errors I always Shrink/Backup the movie with the custom settings on 99%.
    After that Nero always burns the new files Ok and I barely miss the 1% extra shrink.
    CU, Jem.
