i converted a avi to mpeg1 with tmpgenc and the i tryed to open i to auther it with ulead dvd movie factory but it says that the file is not compliant wot have i done wroung
edited your subject, please use subjects that describes your topic / Baldrick
Results 1 to 22 of 22
That is not a compliant DVD resolution
Tried all what
Try a forum search is just part of my signature it is on every post i make. Like I said you have not used a compliant resolution. If you are making VCD load the appropriate VCD template in TMPGEnc. This will have all the setting to enable you to create a compliant mpeg. You just need to choose between pal ntsc or ntscfilm
ok i had a good look about and would this if i necoded it: DVD PAL (MPEG-2 720x576 25fps CQ 65, Layer-2 48000Hz 384kbps) sorry i didnt say lasnite its a dvd im trying to encode
could sum 1 plz tell me wot the righet settings to encode a a avi file to dvd in tmpgenc once i have loaded in the dvd template wot bite riate do i set it and this ther any thing esle i need to change to make it an compliante dvd file
The bitrate depends on the length of the film and whether you want to fit it on 1 disc or not. Higher bitrate = bigger file. Use a bitrate calculator (see tools section) to determine the maximum bitrate you can use and still get the video to fit on 1 disc.
would this b an compliant file:MPEG-2 720x576 25fps CBR 5300kbps, Linear PCM 48000Hz 1536kbps
I would suggest using a vbr bitrate, that way the bitrate is allocated where it is most needed, something like 8000 max 5000 avg and 2000 min, for even better quality you can use 2 pass, but this will double the encode time. Where did you get those audio settings TMPGEnc encodes to mpeg-1 audio layer I or II, with a default of 384kbps. Using PCM audio takes up a lot of space on the DVD and is unecessary
tmpgenc done all the settings for me. is best to use the wizierd in tmpgenc or do it my self
What I do is use the wizard, then change a few settings, such as bitrate, video arrange method and motion search precision.
but when u use the wizared u cant change the settings can u?i thought the only way ucould change the settings is to cancel the wizerd then load the dvd template then load the unlock
Yes you can change settings, such as bitrate. The settings you can't change are those that would cause the mpeg to no longer be DVD compliant. Resolution for example. If you tried it for yourself you would see this to be the case.
been trying to do this all day now would this b the right out put settings: DVD PAL (MPEG-2 720x576 25fps VBR 4840kbps, Layer-2 48000Hz 384kbps)
DVD PAL_4_3_LowResolution (MPEG-2 352x288 25fps CBR 3688kbps, Linear PCM 48000Hz 1536kbps) or would that bthe right one
This would be a compliant file, you can change the bitrate to suit the length of video. I.E get it to fit on 1 disc. The shorter the film, the higher the bitrate you could use, more bitrate=greater quality, providing you have a good source.Originally Posted by mark845
Ulead Moviefactory 6 transition Help
By musickerns in forum Newbie / General discussionsReplies: 2Last Post: 18th Jun 2011, 14:26 -
Adding 'copyright' info to video clip in Ulead DVD Moviefactory 6
By colinb1 in forum EditingReplies: 3Last Post: 19th Apr 2011, 08:13 -
Ulead Moviefactory
By acw in forum Newbie / General discussionsReplies: 10Last Post: 24th May 2009, 01:51 -
Can't get video to import into Ulead, premiere or vegas
By nagihcim1 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Aug 2007, 22:37 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 11:43
i couldnt ov done it with out ya
