Hi all,
I need your help regarding an audio problem
I am trying to back up Miss congeniality
the VTS_1 title set which is the movie has 5 PGCs
So I used dvd decrypter to rip each PGC individually.
I set DVD decrypter in ISO moide then I enabled the streaming process and demux all
I reencoded the movie with CCE but did not touch the other PGCs
So after ripping all PGCs, I usually have for each PGC 1 AC3 file with 6 channels and another one with 2 channels (sometimes I have 2 files with 2 channels)
But there is one PGC (PGC3 which has only an AC3 file with 2 channels)
I reauthored the title set by recreating 5 PGCs, dropped the AC3 files rfipped by dvd decryptor, set the chapters in the main movie and press start to generate the vob files
Then I have the following errors
Error Number of channels are different between VTS_01_1 - 0x80 - Audio -(7) and VTS_01_1 - 0x83 - Audio -(2).
Error LFE channel are different between VTS_01_1 - 0x80 - Audio - and VTS_01_1 - 0x83 - Audio -.
Error Bit rate are different between "AC3 Audio "VTS_01_1 - 0x80 - Audio -""(384000) and "VTS_01_1 - 0x83 - Audio -"(192000).
Error The Audio Attribute(Language, coding mode and so on) in PGC<PGC_3>:Stream<0>:Title<Title_1> is different from The Reference PGC<misspgc1_d2v-vfapi-t-pgc>
I each of my PGC apart of 3, the first audio track is a 6ch follow by 1 or 2 other tracks with 2 channels
Only PGC 3 has one track (0x83) with 2 channels
How can I fix this problem ?
I have seen people talking about dummly audio tracks ?
is it what I have to do and if so how to create a dummy track ?
Thanks for your help
The problem is that Scenarist requires you to have the same audio options within an VTS. Have this scenario, the main feature have this audio options:
5.1 English 448 kbit/sec
2.0 French 192 kbit/sec
now ALL pgc's and titles MUST have the same LANGUAGE, CHANNEL and BITRATE on the tracks. It will now work properly. It did for me atleast =)
Chazzie
Scenarist Mux Server Problem...Anyone?
By Thommers in forum Authoring (Blu-ray)Replies: 4Last Post: 11th Jun 2009, 13:06 -
Scenarist 4.3 subtitles problem
By paulspurrier in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Jun 2009, 06:16 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 01:08 -
error when import subtitle in scenarist
By pcb in forum SubtitleReplies: 4Last Post: 17th Feb 2009, 05:38 -
Scenarist Menus
By nx01rules in forum Authoring (DVD)Replies: 5Last Post: 11th Nov 2008, 00:22
