I'm just beginning to appreciate how useful VirtDub is for compressing files. However, I can't seem to get it to work as a Tv-Capture app. coz I can get any sound to work on it.
Some background info on what i'm using:
- Video Capture Device - MSVideo: Brooktree PCI Video Capture driver
- Audio Recording device - SB Live! Wave In
Is there anything else I need to configure or look into?
Thanks in advance for any advice
well you can make sure your line-in isnt muted.
i had that problem once,, but still have another problem -
Make sure you have the LINE_IN Checked in the Record Control option of your soundcard.
Also UNCHECK the LINE_IN in the Play Control option of you soundcard.
And of course make sure you have the lead from your audio source going into the correct connection on your soundcard.
virtualdub capturing
By cesar110 in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2011, 23:17 -
Capturing DV - Editing with Virtualdub
By LSchafroth in forum Capturing and VCRReplies: 5Last Post: 27th Nov 2009, 20:19 -
Bitrates, capturing with VirtualDub
By epicap in forum Capturing and VCRReplies: 4Last Post: 3rd Sep 2009, 10:49 -
Capturing using Virtualdub with Vista
By qwerty99 in forum Capturing and VCRReplies: 17Last Post: 27th Feb 2009, 20:59 -
What level should I set the audio to when capturing analog in VirtualDub
By drinklime in forum AudioReplies: 3Last Post: 20th Jan 2008, 08:45
