I have burned Ritek 4X DVD-R with no problems but I am having problems with Princo DVD-RW after they are burned. They burn and format with no problem but the burner does not see them in the drive after that. I used Ulead Movie Factory with them and every thing went great. Again drive say,s please insert disk when it is already there?
Any suggestions please.
Bob
Results 1 to 11 of 11
Some people do have Poblems with Princo's using the 105, I would just stay away from that cheap media and stick with Riteks what I use and never have had a problem with them.
same problem here. the 105 can write, but cannot read (?), the princo dvd-rw. the disk should be readable in other dvd-rom drives (and even my dvd player).
question: if you insert the burned princo dvd-rw into a regular dvd-rom drive, does the drive make a strange cracking noise (like it is trying to recalibrate the head) before reading the disk?
thx -
The drive makes a strange moaning sound in my DVD-rom with the Princo DVD-RW but says disk is unreadable.
Bob -
This problem is solved with the new firmware (v1.2x, 12/24/02) from Pioneer's webpage.Originally Posted by robodeb1-MPB/AZ
You may need to update it again. I had this EXACT problem with my 105 fresh out of the box in late December, updated, problem solved. All media read fine now. Unless you've got a third-party firmware or something odd like that (Cendyne/Sony/Apple/etc) in your 105, I don't know what else to suggest...Originally Posted by robodeb1
Good luck!-MPB/AZ -
I seem to have misplaced that firmware update 1.21 I checked Pioneer site and they don,t seem to have it for 105. Any guidance here?
Thanks- Bob -
I found problem--I deinstalled software for" VOB program and CDclone " removing elaborate bytes software and started to read DVD-RW. I will have to try each program seperately to see which one screws up. Thanks for any help though.
Bob -
The 1.21 firmware update is here:Originally Posted by robodeb1
http://wwwbsc.pioneer.co.jp/product-e/ibs/device_e/dev00001r_e.html
Pioneer DVR-530H:Cannot burn to DVD-Rs, works with DVD-RWs
By boba_dk in forum DVD & Blu-ray RecordersReplies: 33Last Post: 31st Jul 2015, 13:24 -
WQXR 96.3 FM classical music radio station moves to 105.9 FM, New York
By vhelp in forum Newbie / General discussionsReplies: 1Last Post: 8th Oct 2009, 22:16 -
edited material back to tape. Sony DCR-105.
By freelance in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 15th Nov 2008, 11:06 -
Does Pioneer DVR-112D burn DVD+R and DVD+R DL media well?
By palmtree in forum DVD & Blu-ray WritersReplies: 26Last Post: 4th Jan 2008, 04:22 -
Illegal Disc Error w/Pioneer DVR-105 in Nero
By Quadzilla in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Aug 2007, 13:23
