Hello,
I was wondering if it is possible to join to encoded files together or is it better to join two AVI files together first and then encode. I'm using Virtual Dub and TMPEng.
Thanks,
Mythos
In TMPGenc go to file - Mpeg tools. U can join 2 mpegs together in the "merge and cut" section, if they r the same bitrate etc. Failing that in Virtual dub go to file - append avi segment for joining 2 avi's
you know it's the anti-Midas touch when all you touch goes to shit.............. -
you can encode multiple source files to one mpeg with CCE , TMPGenc, and Main concept encoder .
w/ TMPGenc the source files have to be avi files to do this. -
Thanks for the information. I may have to add a harddrive to keep several large AVI files. I was hoping to do a 30 minute AVI, encode it, get rid of the AVI after I check the encoded file to see if it is ok. Then I was going to do the same with another 30 minute AVI and finally join the two encoded MPEG2 files together.
Thanks.
Mythos -
they have to be added together on all the encoders i mentioned .. if you need to do what you suggest, you will have to join the mpeg's together.
Why are my encoded DIVX files coming out blocky and pixelated?
By peggypwr1 in forum Video ConversionReplies: 18Last Post: 31st Jan 2017, 07:18 -
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 10:35 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 18:55 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16 -
no sound on encoded files with MCME
By marukomu in forum Video ConversionReplies: 2Last Post: 20th Jun 2007, 09:05
