Dont know where to post this, so Newbie it is.
Recently upgraded to win2k and since then, I cannot view XViD with either win mediaplayer or WinDVD. Just get the classical green screen and then a highly pixalated image.
Have installed the latest DiVx codec (Nino 5.0 build 8) and the XVid codec (even though it is included in Nino). Have removed/installed a dozen times with no effect.
Any ideas??
Install the latest xvid codec from the xvid website
I also had trouble with xvid. I uninstalled Nimo and after that koepi's build of xvid and don't have any problems anymore. Also I'll never install Nimo again!
See if this works.
Uninstalled all DivX codecs and xvid codecs,(Nimo Pack etc.)
You can then install xvid codecs from here:
http://www.divx-digest.com/software/xvid.html
Then install all DivX codecs separat (Not from Nimo).
http://www.divx-digest.com/software/divxcodec.html
After that install Nimo Pack but uncheck all divx codecs and the xvid codec and also uncheck a direct show filter which is Ffdshow DirectShow
Install Nimo from here:
http://www.btinternet.com/~nimosiro/
Now all should work fine!
By the way,AC3 comes with the Nimo Pack and I installed this with
Nimo Pack Build 8,not the new Build 9.
I have posted this all over in this forum so please search for more about it before you start a topic about xvid problems,just start a topic about it if it doesn´t work. -
Thanxs guys...
I uninstalled everything and installed the latest version ofkoepi's xvid and everything is workin great.
Black blocks/artifacts when viewing XVID on TV
By skribby in forum Newbie / General discussionsReplies: 4Last Post: 21st Feb 2012, 08:48 -
DVD for viewing on tv?
By frenchman96 in forum Video ConversionReplies: 1Last Post: 15th Jan 2010, 11:09 -
viewing hf200 on tv
By jim_joh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 13th Oct 2009, 19:20 -
Help Viewing Videos
By Demonolith in forum Newbie / General discussionsReplies: 2Last Post: 11th Jul 2007, 11:03 -
Converting For Better Viewing
By The Sumerian in forum Video ConversionReplies: 1Last Post: 16th May 2007, 10:06
