read http://www.vcdhelp.com/vcddvdr.htm for convert vcd on dvd...
i follow all the steps there but WHEN I DO THE SIMPLE MULITIPEX part it comes out error ( 125042 s packets cause buffer underflow. The MPEG FILE MIGHT CAUSE ERROR WHEN IT PLAY)). so i come to this fourm searching for some answer. i found i can use bbmpeg for that multipex part. and NO errors shows up.. so i conintiue my next step converting vcd on dvd. using MovieFactory 2. and i burn 5 episodes(5 FILES) of friends tv show on 1 dvd. the PROBLEM IS THE FIRST 10 MIN OF EACH EPISODE IS FINE after THAT THE SOUNDS LIKE 1-2 SEC FASTER THEN THE VIDEO. anyone knows?
thank you for reading this.
TMPGEnc DVD Author-sound?
By Mållgan in forum Authoring (DVD)Replies: 2Last Post: 14th Apr 2009, 06:51 -
Sound turned to white noise when using TMPGEnc Xpress & DVD Author
By Hal05154 in forum Authoring (DVD)Replies: 4Last Post: 15th Jan 2009, 23:03 -
TMPGEnc DVD Author & Dolby 5.1 Digital Sound - Can it be Done??????
By Sparehead01 in forum EditingReplies: 2Last Post: 28th Dec 2007, 15:53 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 20:40 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 17:00
