Hi,
Like the subject says, is there an AC3 codec?
THanks Doot
Try the Moonlight Odio Dekoda, Universal AC-3/MPEG Audio (Layer 1/2/3) Decoder - it is described in KingJohn's Guide for Codecs on the main page
Panasonic DMR-ES45VS, keep those discs a burnin' -
Nope. Truthfully there is no AC3 Codec. Only decoders. And seperate encoders (I use BeSweet).
I was only wondering that if you encoded divx files with an AC3 2 channel audio you might be able to lower the audio bitrate as I belive that AC3 is a better compressor than MP3
If your gonna use AC3, its gonna be because you want surround sound. AC3 stereo is poitless.
Installing 32bit AAC ACM and AC3 ACD codec on Windows 7
By pchan in forum Software PlayingReplies: 3Last Post: 26th Apr 2012, 14:53 -
Wrong Codec ??? (for DTS to AC3 conversion) Please help!
By KushSmoka420 in forum AudioReplies: 4Last Post: 29th Dec 2011, 07:50 -
Trouble installing AC3 ACM codec on 64 bit OS
By Teemo in forum AudioReplies: 0Last Post: 30th May 2011, 15:42 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 17:47 -
Audio doesn't play in AVI files, although AC3 codec IS installed
By DVantrease in forum Software PlayingReplies: 2Last Post: 16th Jan 2009, 17:57
