Two nights in a row with the same movie at almost the same point (61% & 71%) I have gotten strean writing Errors. Does anyone know a fix for this?
The only time I`ve had stream errors its been due to not enough space left on the partition I`m writing to.
i realized what it was, win me will not support files larger than 4 gb. TMPG fails when the files get to 3.99 gigs. So now my question is, is there a fix for this? or is there somethign i should do differently in TMPG as far as settings go?
The fix is changing to Win2K or WinXP and using NTFS file system(no 4 GB file limit).
Are you making a DVD?
Need advice
By Nator in forum ComputerReplies: 2Last Post: 29th Mar 2012, 11:06 -
New PC advice
By neworldman in forum ComputerReplies: 14Last Post: 19th Feb 2010, 10:17 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2008, 00:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39 -
I need some advice
By CM World in forum MediaReplies: 1Last Post: 6th Aug 2007, 05:58
