Hi!
I used to capture with an old WinTV and VirtualDub using PicMjpeg. 25 lost frames per movie were normal. Hard drive activities caused by other programs running while capturing did NOT cause any additional dropped frames.
I could even capture while TMpeg converted another file at the same time. And everything was running on a computer with 1GHz Duron, SDRam and a 5400rpm hard drive. The system was solid as a rock.
Now I bought a Terratec Cinergy 400 (SAA7134 chip), because the WinTV was mono and the SAA-chip has a 9-bit A/D conversion for better video quality. And there are only WDM drivers.
Every program I use was very sensitive to hard drive activities and produced lots of dropped frames. The most stable programs I found are FLY2000TV and iuVCR, which cause approx. 90 dropped frames if no other program runs while capturing.
Are the Terratec drivers buggy or is it just the WDM system that is quite useless for capturing?
Are there any VfW drivers available for SAA7134 cards?
M!chael
Results 1 to 1 of 1
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
mencoder: seeking to frames (or cropping start frames)
By manchurian_candidate in forum LinuxReplies: 3Last Post: 13th Dec 2010, 09:53 -
VLC Media Player - "Lost Frames"
By Ancalagon in forum Software PlayingReplies: 3Last Post: 18th Feb 2010, 06:57 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59 -
VirtualDub and WDM Drivers?
By 1gnition in forum Capturing and VCRReplies: 3Last Post: 19th May 2007, 12:11
