I'm really getting tired of this. After some CD-r's, a lot of CD-rw's, and losing some milimeters of my shoes, I don't know what to do anymore.
I have a movie, and a srt file.
-I converted the movie to a sub file (through SSA)
note: I tried everything on SVCD and CVD-subtitle way
-Next I used WinSubMux, to multiplex the sub file with the movie.
-I tested the file with the same program, and it said it worked
>Finally I burned the subbed movie, at none compliant way (or else I would lose the sub, I red somewhere)
Result, movie works, but the timer at the display starts acting strange, from 14 seconds, till 15 appears it takes about 3 seconds, and another 3 seconds before 16 is visible, I can select a subtitle, but it doens't appear (when it's supposed to)
>I also used VCD Imager GUI, to create a bin file, burned it with nero, result: timer acts strange again, dvd-player 'crashes' (doesn't give a response any more, just stops), this happens when I start with the subtitle, or without. To make it more strange, if I start at for example 5 minutes after the beginning, the subtitle works okay, and the timer too! But the beginning just doesn't work, it crashes at the moment it should display the first subtitle line
>And I tried VCD easy too, created a bin file, burned it with nero, and I get the same result as with VCD Imager, but now without sub.
My DVD-player is able to play subtitles (it's a Philips 622).
I tried the examples for the subtitles (on this site), and they worked on my player.
Please, is there somebody who can help me?
ģIf you need more information, just ask it!
Results 1 to 1 of 1
Post your movies here!
And while you're there, please tell me what I can improve in my movies!
AVI with selectable subtitles?
By davroglor in forum DVD RippingReplies: 1Last Post: 14th Jan 2009, 11:27 -
Adding a menu and selectable subtitles
By HAR in forum MacReplies: 0Last Post: 15th Sep 2008, 05:25 -
By macuser1960 in forum ffmpegX general discussionReplies: 8Last Post: 6th Feb 2008, 21:10 -
How to burn a DVD with TWO (2) selectable set of subtitles?
By DaPuertorican in forum MacReplies: 0Last Post: 22nd Nov 2007, 12:27 -
DVD selectable subtitles
By exekutive in forum ffmpegX general discussionReplies: 6Last Post: 24th Sep 2007, 12:36
