I am having a problem with video color quality – it lightens and then darkens every few seconds.
I downloaded two of those 150MB files from P2P file sharing network. I believe the files are Divx coded. I am trying to convert them to Mpeg so that I can burn them onto a CD to play as a VCD.
I am using TMPGENC to do my encoding. First, I checked the files in VirtualDub for bad frames and they have none. Then went into TMPGENC. Here are the choices I made:
Create NTSC Film
Video Type is non-interlace
Field Order is Top Field First
Aspect Ratio is 1:1 VGA
In Other Setting or Expert Settings, I made the Video Arrange Method Full Screen (keep aspect ratio). I did not change Motion Search (left normal) or Reduce block noise (left unchecked).
I am very happy with the visual sharpness of the resulting Mpeg file. When converting from a 150MB file that has 60 minutes of movie, one cannot expect perfect picture. However, the color fades in and out during the movie and the original has perfect color or t color s constant throughout.
Does anyone know of a fix for this?
Please help. Thanks.
PAL MPEG-2 to NTSC MPEG-2 - Different Color on TV
By HoosierGuy in forum Video ConversionReplies: 20Last Post: 5th Apr 2011, 12:43 -
How to maintain color in mkv conversion?
By vato76 in forum Video ConversionReplies: 10Last Post: 15th Apr 2010, 10:53 -
conversion loses color
By ranchhand in forum Video ConversionReplies: 13Last Post: 14th Aug 2008, 22:46 -
DivX to Mpeg -> DVD Conversion is Jerky
By jedijfo in forum Video ConversionReplies: 4Last Post: 15th Oct 2007, 08:32 -
Color flashes during conversion
By vertical in forum Newbie / General discussionsReplies: 6Last Post: 8th Jul 2007, 18:10
