hi can anybody help using TMPnc Plus tried to convert harry potter 2 to DVD to transfer to DVD the only problem is there is no sound i used to use the old TMPGEnc and could just use a standard template for DVD and there was sound since i have changed i cannot get the sount now to work
If you have just installed another TMPGEnc, check your VFAPI plug-ins, make sure the priorities are high enough. Load your old TMPGEnc and check what you had before
Options > Environmental settings > VFAPI plug-ins >
What is the source ? AVI > DirectShow Multimedia file reader -
thanks for your reply keep up the good work with your guides they are greatill give it a go
once again thanks
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 21:10 -
TMPGEnc DVD Author-sound?
By Mållgan in forum Authoring (DVD)Replies: 2Last Post: 14th Apr 2009, 05:51 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 16:12 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 16:00 -
TMPGEnc Plus and AVI sound
By busdonic in forum Video ConversionReplies: 5Last Post: 22nd Jun 2007, 10:18
