I'm looking for a DVD Authoring/burning program that will give me the option to have each chapter play in my DVD player and stop after each chapter has played....and then return to the menu so someone could either play that one again...or chose another chapter to play.
Is there one that is that advanced?(along with playing straight through if I don't chose that option)
well with maestro this is easy ,,
and you can do it easy with impression pro also in terms of the stop after each chapter and go to main menu , but im not sure how you would select play straight through then (in maestro it is done w/ a play list) -
I've tried that one before, but it was so user Unfriendly to figure out, I quit using and got rid of it before learning it could do that(or much else for that matter).
Is Impression Pro any easier to use? -
well i think maestro is one of the easiest to use , so maybe im not a good judge..
impression pro is even easier yes ..
Authoring Blu-ray with chapter points
By ikarishinji41 in forum Authoring (Blu-ray)Replies: 2Last Post: 28th Jan 2012, 06:44 -
Chapter stop question
By Ronny G in forum Authoring (DVD)Replies: 2Last Post: 18th Feb 2008, 11:31 -
How do I stop a DVD from repeating the program?
By billlaux in forum Newbie / General discussionsReplies: 6Last Post: 23rd Jan 2008, 21:51 -
Authoring DVD's with more than one cell per chapter
By usually_quiet in forum Authoring (DVD)Replies: 2Last Post: 14th Sep 2007, 10:10 -
Avid Lquid 7 menus..play chapter and play all
By cheesypuffs in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2007, 02:34
