  1. Hey
    Why can i capture over 17 frames pr sec in V dub??? is there somewhere I haft to set it to 25 frames......i have try to do it but it just loose the last 8 frames. I have tryed to set down screen size but that dosenīt help... It just wount go over 17 frames, its like if there were some kind of limit!!!
    Goodboy
  2. File
    Capture AVI
    Capture
    Settings
    Framerate (set to the framerate you require)
    Vdubs default framerate is 15 fps
