Another CCE setting question!
I always check with bitrate viewer to see the way a particular m2v file has been encoded. For the most this is quite straight forward.
A file I am currently looking at (Oceans 11) states that it is "Quantscale: NonLinear". Looking at the settings in CCE you have the option to use Linear quantizizer scale or not. I have assumed for this file I should select not to use it. However, looking in the CCE advanced guidebook, it states that non linear is recommended for Mpeg2 unless there is a "special reason".
Is this a special reason do you think?
I'm midway through ATM of the conversion, so will know I guess shortly. I am however seeking advice so I can understand this a little better if anyone knows.
Many thanks in advance.
Regards
Les 8)
I always activate the options in CCE in result of what bitrate viewer shows me.
I have made more than 50 movies, some of them I had to activate Quantscale to linear and some to nonlinear, and I didn't have any problem with movies that are nonlinear. -
Shortly after I posted I decided that I would take note of what it said in the CCE guide, and I stopped the encoding in its tracks. I had a quick look at what it had done, and it did seem fine. But I have now set it to run with the check box checked for quantizizer set to non linear.
Anyone know what it actually means or does?
Cheers
Les -
He he - after reading your post Neopunk, I decided to go back to how I had set it originally!
I did however have a peak at what it looked like set as linear, and to be honest, I couldnt see any difference at all! Mind you that was on a PC monitor!
Les
Best CCE settings for 16x9 progressive video?
By mlong30 in forum Video ConversionReplies: 0Last Post: 18th Apr 2011, 08:22 -
Capture Video Settings - Input Type Missing
By TechnoBill in forum ComputerReplies: 2Last Post: 2nd Jun 2009, 04:02 -
Question re settings in CCE Basic
By eclipse95 in forum Video ConversionReplies: 4Last Post: 6th May 2009, 16:17 -
question about settings and best file type on cheap TV card
By jimdagys in forum Capturing and VCRReplies: 2Last Post: 29th Nov 2007, 02:09 -
Best Advanced CCE Settings in DVD Rebuilder
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 11:56
