  1. Is it possible to have music in the background at the menu screen on a VCD?? I am using Nero and i can't find a way to do this.
  2. Yes you can.
    With Nero you can't.
    There are generally two ways to make a menu on a VCD with audio in the background.
    (1) to use a video clip as the background for the menu
    (2) to use an audio only segment play-item ( http://www.geocities.com/mikk999/StillsWithAudio.htm )
    http://www.michaeltam.com
    http://www.vcdeasy.org
    The disadvantage of using (1) is that video clips for VCDs are limited to 352x240/288 and this is usually insufficient for text. The situation is better for SVCDs.
    The disadvantage of doing (2) is that this doesn't work particularly well on many DVD players.
    Regards.
    Michael Tam
    w: Morsels of Evidence
