hi, i was wonderin why the xvid movie i have is all in green blocks the i realised its prolly the codec, i was usin windows media player to watch it, ive got a couple of questions if anyone could take the time to answer
what codec should i use, ive tried the ones with the nemo pack and they dont work for me.
does windows media player play xvid?
what program would i use to encode xvid, ive tried tmpeg but to no avail
thx fellas
See if this works.
Uninstalled all DivX codecs and xvid codecs,(Nimo Pack etc.)
You can then install xvid codecs from here:
http://www.divx-digest.com/software/xvid.html
Then install all DivX codecs separat (Not from Nimo).
http://www.divx-digest.com/software/divxcodec.html
After that install Nimo Pack but uncheck all divx codecs and the xvid codec and also uncheck a direct show filter which is Ffdshow DirectShow
Install Nimo from here:
http://www.btinternet.com/~nimosiro/
Now all should work fine!
By the way,AC3 comes with the Nimo Pack and I installed this with
Nimo Pack Build 8,not the new Build 9. -
I had the same problem for about a week. Would get either green blotches or mplayer would perform an illegal operation and shutdown.
I have a GeForce3. Tried the G400 Filter and everything worked fine using Windows Media Player 7.
Nimo warns to not use unless you have a G400 graphics card(Matrox). Digital Digest reports that GeForce cards may also benefit from this filter.
The experts, (which I am not), may disagree with this, but it was the only thing that worked for me.
xvid target size problems
By Cowabunga in forum Video ConversionReplies: 13Last Post: 16th Jan 2009, 16:11 -
XViD 2nd pass problems
By shorto in forum Video ConversionReplies: 2Last Post: 22nd Dec 2007, 18:31 -
Problems with XViD
By trolldown in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2007, 17:32 -
Xvid playback problems
By drwho in forum Software PlayingReplies: 7Last Post: 13th May 2007, 22:14 -
3ivX to XviD problems...
By GangstaRap in forum Video ConversionReplies: 8Last Post: 6th May 2007, 12:25
