  1. Everytime I go to import an mpeg to SpruceUp, it freezes betwen 6-20%, then it stops loading the mpeg. My Mpegs were done with TMPGnc at
    MPEG-2 352x240 29.97fps CBR 1700kbps, Layer-2 48000Hz 224kbps
    someone please help
  2. Member wingnut's Avatar
    Sep 2001
    Dorset, UK
    Hi there
    I had this particular problem when starting with spruce up, try using
    TMPGENC to demux the mpeg into an mp2 and m2v in the same directory with the same name e.g. fred.mpg becomes fred.mp2 fred.m2v
    then inport fred.m2v and it should open both ok
    Regards
    Ed
  3. Ed
    thanks for the help. I split the audio and video, and still didnt work. Only change I had to make was rename the *.mp2 to *.mpa.
    Now I can finally clean out about 30 gigs of mpegs
