I understand that when I rip a dvd that I am using alot of HD space but it fragments so much that on my system it takes 12 or more hours to defrag it.
athlon 1.4 t-bird
512 ddr CRUCIAL
30 and 80 gigs
radeon 64 meg 8500
I am using XP pro with ntfs and use the 80 gig for video and extra stuff that is backed up on DVD-RAM. Would it be easier to just format the 80 with ntfs? And if you recommend it how do I do it? I mean is there an easy way without having to boot from a 98 boot disk.
Is there any particular reason why you want to defragment the data? You can probably rip and encode without doing so. I don't bother to defrag after I rip a DVD.
I would format the 80Gig drive with NTFS. -
It should not take 12 hours, that's for sure!
I can defrag my 120Gb drive in about an hour (or it seems like that - never actually timed it).
Regards,
Rob -
Too right mate 12 hours means there is something wrong with your disk. I recently changed two 40gb disks to ntfs and even with extreme fragmentation and less than 10% free they defrag in less than two hours ... much better than win98. BACKUP YOUR DATA NOW! then run scandisk thorough. then you probably need to do a low level reformat to flag your sectors in error
ROCK ON ACorn-computers...BBC B ....best PC ever...
:P
The electronic components of the power part adopted a lot of Rubycons.
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 15:58
