  1. Setup:
    VCR connected to Canopus ADVC-50 (composite) connected via Firewire card to DV type 2 avi file
    Capturing with Scenalyzer (and tried Vegas Video).
    Encoding with TMPGenc basic DVD type template.
    It seems when everything is converted and I watch it on my standalone DVD players there are these white lines that show up every now and then around the screen. Not really sure how to explain it. I was wondering what might be causing these and if they are correctable.
    I am thinking it is possible to be my VCR because it is sorta a cheap generic type VCR.
    Anyone have any suggestions??
    Apr 2002
    The State of Frustration
    I think it may be your capturing program. May be you should try another. I capture with a $59.00 VCR once in a while, with Video Studio, and ir captures fine. Maybe you should try its demo, or maybe Virtual Dub.
    Hello.
  3. Who makes Video Studio? I have now tried a 3rd program - iuVCR and that does the same thing. I bought brand new cables so i know its not the cables. The only other thing i need to try is a different VCR.
    I would try VirtualDub but for some reason I can't get it to work with my setup. I see no preview. I would like to get that working. I have a Canopus ADVC-50.
    Anyone else have any suggestions?
  4. Video Studio is by Ulead.
    www.ulead.com
  5. Thanks. Tried Video Studio and got the same problem. You can actually see the white lines during the preview so I know it probably isn't a capturing problem per se.
    The only things I can think of are: 1. VCR, 2. Firwire card/cable, 3. ADVC-50 card.
    Anyone have any other suggestions or have seen this before?
