My audio and video looks good until I burn it to DVD, that's when it gets off. I am using Ulead DVD Movie Factory to burn my DVD. My Burner is a Pioneer A05, if that makes a diffrence. Can someone tell me what I am doing wrong or sugest another Program to use for burning that will not throw off the the audio sync!?!?!?
Thank You
Hi Airborne
I am having the same problem. I am capturing with a win-tv PVR 250.
My Specs:
AMD Athlon XP2200 (1.8GHz)
512 MB DDRAM
100G Hard Drive
120 GB Capture HD
Windows XP
Custom capture profile:
Program, VBR, 7000 max bitrate, 5000 minimum
Video looks great when Burned on DVR-105
Burned using DVD MovieFactory 2-Trial version
However, the audio goes out of sync about 30 minutes into the program. It appears the video is ahead of the audio by at least 1 sec
When viewed using WinTV there is not an issue with A?V sync...everything looks perfectly.
Is it an issue with MF? What other burning apps have people had success with?
Would it help to do a simple multiplex with TMPGenc? Probably not since I don't think the problem is with the capture.
Thanks in advance for any suggestions! -
I am wondering if it isn't an issue with Movie Factory. I haven't tried any other programs to burn with, mainy because I don't know of any others
I have been following this guide http://www.vcdhelp.com/forum/userguides/114252.php
(well at least the part of DVD2SVCD), and then converting the file to MPG2 with TMPGEnc. Before burning with MF I check to make sure the audio sync is ok, and it is, but the burned DVD is out of sync (as previously stated).
My specs are:
P4 1.8
512MB DDR
40 Gig HDD
Geforce 2 MX440 64MB
Avermedia TV Tuner
creative Audigy Platinum sound card
Pioneer A05 DVD-RW
Iomgea CD-RW
Creative 52X CD Rom
Windows XP Pro
Thanks and Aloha -
I also had the same problem. There is a patch to correct this problem on the Ulead website, for Movie Factory 1, download "CD/DVD Burning Patch" . It works for me.
Not sure if it's compatible. I'm using the full version. Try their homepage, http://www.ulead.com/
Audio video sync problem
By FrankieToh in forum Newbie / General discussionsReplies: 0Last Post: 3rd Dec 2010, 07:53 -
Audio - Video Sync Problem - VirtualDub
By cyberlion in forum EditingReplies: 13Last Post: 16th Jul 2010, 07:51 -
Audio Video Sync problem
By m baqar in forum Authoring (DVD)Replies: 1Last Post: 27th Mar 2008, 00:59 -
After downmix audio video sync problem
By adarkenigma in forum Video ConversionReplies: 7Last Post: 17th Oct 2007, 09:10 -
Audio/video sync problem
By Hekey Williams in forum DVD RippingReplies: 1Last Post: 8th Oct 2007, 04:27
