I downloaded files from a site that work whenI view in Divx. I want to put them on my dvd player. What should I use?
RHK
I guess I'll bite since nobody else has. Look, you need to read the guides on this site, i.e. divx to dvd-r, avi to dvd-r, etc. The short answer is that you will need to encode the files to dvd compliant mpeg2 format, import that file into an authoring program like DVD Maestro or Spruce Up and then burn the resulting files with Nero or Record Now. There are many steps that require reading. There are many guides and many are quite good with pictorials to assist.
<----------see that green bar? that's where you can get your answers. you might also want to click on the blue bars where it says: "WHAT IS"
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40
