I just ripped the movie XXX useing smart ripper. I converted it with DVDX. When I viewed the movie before burning it, the director talked through the whole movie. Does anyone know how I can get rid of that?
You must have had the wrong audio track selected when you were encoding...go back and look for the proper audio track setting in your encoder.
the problem is that you have selected the wrong sound track, try using another track.
i had almost the same problem and i took care of it with it. -
Set the audio to english, or if several english you have to try them all
http://www.vcdhelp.com/sefy/?id=encoding1.html
VLC : OSD time changing from hh:mm:ss/hh:mm:ss to hh:mm:ss.xxx/hh:mm:ss
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 18th Nov 2011, 08:20 -
Having Issues Running an Original XXX-DVD
By devilcoelhodog in forum DVD & Blu-ray PlayersReplies: 10Last Post: 19th May 2009, 16:27 -
Even xxx wouldn't do this... I think...
By zzyzzx in forum Off topicReplies: 11Last Post: 31st Oct 2007, 15:19
