I am using Premiere to get DV from my camcorder to an AVI, but it is the kind that Virtualdub won't open, and although I can convert it w/ canopus, I would rather just use some other program which will create the original in Type 2.
What software does this?
Can it be captured with Vdub itself?
ZZ
You can use Mainconcept's trial dv codec to allow virtualdub to open dv files. I capture with MS MovieMaker then edit/filter/frameserve with virtualdub. Mainconcept's trial version will produce a watermark if you encode but not if you decode.
What is the best type of camcorder to get to make and edit home videos?
By cschinnerer in forum Newbie / General discussionsReplies: 9Last Post: 28th Jan 2008, 15:40 -
DV AVI Type 2 -> Type 1 converter?
By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 20:16 -
Do they make 5.25 drive firewire enclosures for bluray etc?
By yoda313 in forum ComputerReplies: 4Last Post: 20th Dec 2007, 17:16 -
How can I make an Intro 3d type video for my videos?
By Mysteriouskk in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 17:58
