  1. I am trying to create a VCD from family videos using ATI AIW 128 pro. I am using MMC 7.1 to capture to a file. Everything goes ok. I can use MS MP7 and the files plays all the way to the end about 57min.
    Then I demux (TMPEGenc 12j) the file and the two files are created normally. I replay the video file with MP7 and it reports 57min. I look at the video file is still plays all the way to the end.
    Then I remux (TMPEGenc 12j) and I look at the final file and try to play with MP7 and now the file reports 1hr 58min. What's is going on?
    When I try to create the VCD nero does not report any problems. When I try to play the VCD on my computer of standalone DVD player the disc spins for ever.
    Somehow that extra hr appended to the remuxed file is creating a problem.
    By the way I use the same settings for the remaining part of the tape and no problems whatsoever. I can create the VCD with zero problems. The second part of the tape is about 60min long.
    Does anybody know whats is going on? How to solve the problem?
    I am very fustrated I tried capturing the first part of the tape about 4 times with the same results.
    Pleas help me!!!!
    Roberto
    Feb 2001
    Berlin, Germany
    When you multiplex with TMPG, select type "Video-CD". I guess you set it to MPEG-1 System (automatic).
  3. I made sure last time I demux/mux the Video CD was seleted when muxing.
    Any other suggestions?
  4. See my reply to all
  5. MMC 7.0 and 7.1 have a Problem with Multiplexing. Try MMC 6.2 or 6.3. This Versions of MMC using the Ligos Mpeg Encoder. It produces full VCD 2.0 compliant Mpeg Files.
