How does one demux an ac3 file from a DIVX encoded avi so I can load it into DVD Maestro. I've used Virtual Dub to demux the audio and rename the file as .ac3; however, DVD Maestro still does not recognize it as a valid ac3 file and won't accept it. I'm not interested in re-encoding to a wav file since I want to preserve the 5.1 AC3. Thanks.
There is another option for this.
Demux the ac3 in virtualdub, using save wav. Then rename the .wav to .ac3.
The next thing you do is download a program called BeSplit, and to make it even easier, also download a program called BeSliced that makes your job alot easier. These programs you can find on doom9.org. To fix the ac3-file (rewrite the header to ac3 type), just open up BeSliced(make sure you have it in the same folder as BeSplit) and drag the file into the window that opened, and hit fix file. Wait one minuter or so, and you will have a new fixed .ac3 file.I wanna be bigger, stronger, drive a faster car... -
You can run the demuxed ac3 file through ac3fix
demux avi, mkv file
By volam1 in forum EditingReplies: 19Last Post: 4th Oct 2013, 08:03 -
I want to demux an .mp4 file and convert to a microsoft dv .avi file
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 13th Sep 2009, 22:42 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24
