  1. OK, guys, can ya help me out here on this one? Here's my situation: I've got 14 600 MB segments of a football game (the Fiesta Bowl) that I want to encode into a DVD set. Using Canopus ProCoder, I was able to do this, but there are noticeable audio sync errors throughout the 4.5 hours of video.
    I would like to fix this if I can. My thinking is such that if I can encode the game into a single, continuous file using the AVI 2.0 standard, I would think that ProCoder would not have the errors as it transitions from one segment to the other, as it currently does. For my purposes, the DVD set is satisfactory, but I would like to encode a better-quality set if I can.
    How can I get these segments encoded into a single file?
    Thanks.
    phant0md0g
  2. can anyone help me out here? out of 38 views, i would think someone should know something...
  3. I'm a Super Moderator johns0's Avatar
    canada
    try loading all the files into dvd2avi and save as avi then insert the audio with virtualdub after
    canada
    this will work with mpg2 files,not mpg1
