I'm capturing old anime VHS tapes (NTSC) and converting them to a digital format. When I capture at 352x240 and convert to VCD, the result is fine. After converting a few tapes, I wanted to try coverting one to SVCD. I've tried capturing at 640x480, 480x480, and 352x480 before using TMMPGENC to convert to MPEG-2 (using the template), but after burning and playing the test file on my DVD player, the video has a slight flicker or jitter. I've tried various seetings in TMPGENC but nothing seems to have much of an effect. Any ideas on what I can try or what I might be doing wrong? There was a webpage posted a day or so ago about interlacing. According to the page, you should not deinterlace the source. It also mentioned that Inverse Telecine sometimes improves certain anime, so I tried it and either didn't do it correctly or the orginal VHS wasn't Telecined. I'm kind of at a loss and would probably benefit from an expert opinion at this point.
Thanks,
NiteCretr
DO !() deinterlace, try "deinterlace on even field", it will probably solve your problem.
Well, that's a definite improvement.It's still slightly jumpy, but that's probably because I'm just fixated on it at this point. One question though: why deinterlace on the even field as opposed to the odd field. Any reason?
Thanks,
NiteCretr -
turn on use floating point dct and it will help a little more.
video flickering
By LonghornIII in forum Video ConversionReplies: 1Last Post: 17th May 2009, 19:58 -
Flickering
By artistguy68 in forum ffmpegX general discussionReplies: 0Last Post: 10th Mar 2008, 21:01 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 09:06
