  1. Got 6 mpegs here totally 4.16gig..
    Want to author them as a DVD (all right size etc)
    Tried SpruceUP... goes out of sync
    Tried myDVD ... uses up far to much space apparently (:/)
    Any idea what else to try? Just want a simple menu really ... dont need chapters at all... would like to put my own background picture in though :)
    Thanx
  2. have you ran the Mpeg's through TPMGenc to split out the auto and vid into seperate files. i found spruceup does go out of sync if it is just a single mpeg
    LLAP-Goch... the secret Welsh ART of SELFDEFENCE that requires no INTELLIGENCE, STRENGTH or PHYSICAL courage
    ---Monty Pythons Flying Circus
  3. Yeah had the exact same problem... originally was a 4.2gig ish file... split it into the 6 mpegs ... even when the mpegs are perfectly fine individually, when you split them into its constituant parts ... it goes out of sync :/
