I'm using the lastest ver. of TMPGEnc and trying to encode a asf file to mpeg. However it would take 300h and 29m to encode it into mpeg. There is got to be a faster way. It is not my system either (800mhz P3, 384mb RaM CL3, & TnT2 m64). Is there any program faster than TMPGEnc?
Lang<cIv>
yes
save the file to DIVX
< http://www.geocities.com/mpgtoasf for coded etc ..>
ok .
while it is in DIVX use TMPGENC or PANASONIC MPEG1 ENC
it wil be much faster !
Hey thanks that worked great. Now it takes about 2hs and 10mins to encode the file.
Lang<cIv> -
you welcome .
please link this site
to everyone !
regards
Koby as Goldenaxe4000@yahoo.com
what is divx? and what prog do i use to save the file to divx - and is it going to be .Divx ? - can u be more specific plz
Hi,
Can someone post here how to convert asf to divx? Do you use VirtualDub 1.3c? Ifso, how? By the way, the website at geocitis/mpegtoasf does not work.
Thanks,
Rage
asf to vc-1
By sampalmer21 in forum Video ConversionReplies: 1Last Post: 16th Dec 2009, 14:27 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
vc-1 to asf
By sampalmer21 in forum Video ConversionReplies: 3Last Post: 10th Nov 2009, 19:47 -
Conversion from asf files to avi or mpeg
By Jescal in forum Video ConversionReplies: 1Last Post: 23rd Jan 2008, 16:37 -
Convert AVI to MPEG-4 (asf) for DVD player
By digitalife in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2007, 11:49
