Version 0.20 of VCDMeta is now available.
VCDMeta is a Perl script which makes creating easy to navigate VCD extremely simple. It makes in a simplified XML documents which simply contains a list of the Videos you want to include and how you want them to be arranged. From that it will output a XML document suitable for use with vcdimager complete with easy to navigate menus. A text file "`0VCDINDX.TXT'' is also created which contains the complete contents of the CD for easy navigations when reading the VCD on a computer without VCD menu support. If images are not provided for the menus it will create the menus for you. When the supplied patch is applied to VCDImager, VCDMeta can generating special easy to use mpeg files for use on a computer complete with an HTML index.
You can find it at http://kevin.atkinson.dhs.org/vcdmeta/.
So far VCDMeta has only been testing on Linux but it should work on any Unix like operating system. It should also work on Windows, provided the right tools are installed, with a little effort. I believe all the required libraries and tools have been ported to Windows, but I have not actually tested VCDMeta on Windows.
It really makes creating a nicely structured VCD really easy and has features that most GUI Frontends to VCDImager don't have like being able to automatically create the menues for you.
Results 1 to 1 of 1
AV Linux 2.0 Released!
By GMaq in forum LinuxReplies: 7Last Post: 21st May 2009, 07:51 -
Divx 7 released
By Peakr in forum Latest Video NewsReplies: 44Last Post: 2nd May 2009, 08:52 -
VLC 0.9.2 released
By Brazil in forum Latest Video NewsReplies: 0Last Post: 15th Sep 2008, 10:25 -
MacDVDBitrateParanoia v0.5 now released!!!
By bendermac in forum MacReplies: 12Last Post: 29th Apr 2008, 15:10 -
Safari for PC released
By dcsos in forum Latest Video NewsReplies: 6Last Post: 12th Jun 2007, 11:40
