I downloaded some .avi files from Kazaa. When I play them, there is no sound. I put them in gspot and it says that I have the codecs for them. I cannot figure out how to get them to play so I can encode them. Any suggestions for an old lady that has read and read the forums but still cannot find the answer?
See if this works.
Uninstalled all DivX codecs and xvid codecs if you have,(Nimo Pack etc.)
You can then install xvid codecs from here:
http://www.divx-digest.com/software/xvid.html
Then install all DivX codecs separat (Not from Nimo).
http://www.divx-digest.com/software/divxcodec.html
After that install Nimo Pack but uncheck all divx codecs and the xvid codec and also uncheck a direct show filter which is Ffdshow DirectShow
Install Nimo from here:
http://www.divx-digest.com/software/nimo_pack.html
Now all should work fine!
By the way,AC3 comes with the Nimo Pack and I installed this with
Nimo Pack Build 8,not the new Build 9. -
Ehh why write my replie again?Originally Posted by ssandhouse
Sorry about that. I guess I don't know how to reply to messages either.
Anyways,
I'm not sure if I know how to do that. Do I go into control panel under multimedia and click on the video and audio codecs there? And will they go by the names, Divx, xvid, etc? -
Do you even have installed divx and xvidcodecs yet,if not just install evertying that I wrote in my first reply.
I did have some divx files installed. I found them and deleted the ones I had. Then I went and did what you told me. I had a very hard time finding the Nimo Pack as the links were not working, but I eventually found it, installed what was needed and everything is working fine now. Thanks for your help
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 15:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
