Is there any way to do this??
I know capturing high and re-encoding would probably yield higher quality but I'd still like to check this out if I can. Please let me know if you know of a way to do it.
Jason
It does not support SVCD direct cap, but there is a registry hack to add unsupported resolutions (ie, 480x480). Create a custom profile using the new resolution and set the appropriate max bitrate. This won't really be an SVCD stream since it won't have an SVCD header, but perhaps re-multiplexing as SVCD will solve this. You are right though, this will give inferior quality to re-encoding. A very similare product from Intervideo called WinDVR does have built-in direct capture to 480x480 SVCD.
Internal Capture Card? Possible to Capture direct to PC?
By Ryutso in forum Capturing and VCRReplies: 11Last Post: 25th Jul 2010, 15:58 -
Can someone direct me to a good capture device..
By KameronK in forum Capturing and VCRReplies: 5Last Post: 28th Mar 2008, 21:46 -
DV Direct to DVD (DV Capture)
By coisty1856 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 13th Sep 2007, 14:15 -
Capture / Burn direct to drive
By Bob08 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 19th Jul 2007, 15:28 -
Direct capture from the PC DVD player?
By hitman3000 in forum Authoring (DVD)Replies: 1Last Post: 2nd Jul 2007, 17:37
