I want to burn some VOB files to a svcd. Since I can't use TMPGNE to convert them and nero seems to offput the sound. Does anyone know a good program that will convert these? They are not on a dvd they are on a data cd-r. they are just the files. PLEASE HELP!!!
-thanks in advance
-BSR
Results 1 to 11 of 11
get DVD2AVI
it will extract the sound for you and convert it to WAV, and create a d2v file that you can load into TMPGenc -
sorry, im a bit new at this, but how can I make d2v file? and can you link me to the dvdavi tool?
thanks -
you can get DVD2AVI from
http://arbor.ee.ntu.edu.tw/%7Ejackei/dvd2avi/
Once you have it, go to FILE->OPEN
select the VOB file you want
hit F4
Check the guides on here if you need anymore help.. there is plenty of info on it -
Why not ?Originally Posted by bigscaryrobot
TMPGEnc Browse > (*.*) > .VOB
You will need an Mpeg 2 filter for this to work, like Ligos
However, why are you not using the IFO to convert all of them at once ?
http://www.vcdhelp.com/forum/userguides/135262.php
Select SVCD for output -
Yea, but then you need to extract and convert the audio tooOriginally Posted by KingJohn
DVD2AVI will demux & decode to WAV that can be loaded into TMPG -
um...Originally Posted by KingJohn
Thats why...Originally Posted by bigscaryrobot
He said he has VOBs on a CDR that he wants to convert to SVCD..
last time i checked (s)VCDs used 44.1K for audio... How do you know these VOBs arent ac3? TMPGenc can use the video from the VOB, but not the audio..
I suppose he could demux the vobs, use besweet to convert to mp2/wav and then load the m2v file into tmpgenc, but using DVD2AVI seems alot simpler and quicker -
Why not ?How do you know these VOBs arent ac3? TMPGenc can use the video from the VOB, but not the audio
ok, i'll bite... how do you load vob audio into TMPGenc?
putting dvd files (VOB) from dvd and using in windows live movie maker
By emmawharmby in forum DVD RippingReplies: 8Last Post: 20th Feb 2012, 06:58 -
Putting subtitles on MP4 files?
By Cooperdk in forum SubtitleReplies: 0Last Post: 6th Dec 2010, 06:09 -
Help putting AVI files onto a DVD!?
By rightsidebrain in forum MacReplies: 10Last Post: 24th Mar 2009, 08:40 -
Putting downlaoded files on DVD
By sofa in forum Video ConversionReplies: 1Last Post: 17th Nov 2007, 22:51 -
Putting 2 QT Files w/ 2 seperate .srt files onto a DVD
By whoracle in forum ffmpegX general discussionReplies: 5Last Post: 22nd Jul 2007, 02:57
