I have 2 parts of a movie encoded in the xvid codec. How can I merge them together so I can splice it into 3 parts for encoding into vcd?
(The movies are 1 hr 28 min each so it wont fit on vcd)
PLEASE Help
Thanks.
like i did: use virtual dub to put them all together (open file, second file you "append video segment")
than you selct a range for cd 1, save that as a avi (video and audio on direct stream copy) and the same you do for cd 2 and 3 -
Thank you
I noticed this article right before you posted
http://www.vcdhelp.com/virtualdubedit.htm
Converting xvid movies
By SJRSMITH1 in forum DVD RippingReplies: 1Last Post: 14th Jul 2011, 00:26 -
quenc 0.72 catching with movies (xvid 1.3.0)
By sgbd in forum Video ConversionReplies: 1Last Post: 13th Nov 2010, 20:41 -
method merging two dvd movies
By asif shafiq in forum Newbie / General discussionsReplies: 2Last Post: 10th Feb 2010, 05:03 -
Best xvid parameters for DV movies conversion
By Boro72 in forum Video ConversionReplies: 1Last Post: 18th Jan 2009, 09:47 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47
