Hi All,
Everytime I try and put a 4.3Gig M2V file into TMPG it locks up. In the Task manager it says it is not responding. Does anyone know a fix for this or has anyone had the same problem?
I waited about 10mins but like I said the task manager said the "Program is not Responding".I read in the Environment settings window that TMPG will not accept AVI files of over 2gig so it may also apply to .m2v files..hmmm. I am currently tring to chop it into smaller sizes to see what happens.
i have loaded huge avi's into tmpgenc (like more than 80gig) with no problems .. where does it say it can not load more than 2gig files ?
anyway -- just frame serve your m2v file with dvd2avi
or
check Environment settings VFAPI and bump up your mpeg2 decoder -
One way is to split the File to smaller parts, it will not just help you with your problem, it will also increase the converting speed
Yours Zoolo!
My MPG2 file crashes everything it touches, - why?
By Bansaw in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2011, 17:35 -
Help! Handbrake crashes shrinking vc1 file
By moggsy in forum Video ConversionReplies: 0Last Post: 13th Dec 2010, 14:49 -
ReelDVD 2.5 crashes when I import PSD file for a menu
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 3rd Apr 2010, 08:21 -
Trying to convert AVI to MPEG file smaller then 4gig
By Lisn2me in forum Newbie / General discussionsReplies: 7Last Post: 30th Dec 2009, 12:01 -
Windows crashes if I play an AVI file.
By Captain315 in forum Software PlayingReplies: 8Last Post: 3rd Apr 2008, 22:24
