I've no idea what brand it is or anything, but here's the link to the page http://cyberguys.com/cgi-bin/sgin0101.exe?UID=2003011616503722&GEN6=00&GEN9=5CG01&HKW=...REQC=3&UREQD=4
A pack of 25 discs is $27.99 or 50 for $55.98 which seems like a good deal for v2.0 media. That should mean that it's 2x compatible, right?
I might just order a couple of the single discs to confirm they work if no one has had any experience with them.
Thanks for any feedback.[/url]
For that price you might as well order some Riteks from somewhere that says thats what your getting. Should be about the same price or cheaper depending on how many you purchase at a time.
I ordered a few from them and they do work on my sony dru-500a but only at 1x but they did work but the riteks are cheaper and do burn on my sony a 2x
For the record: no, "version 2.0" does not mean 2X-write compatible. What it means is "4.7Gb", as opposed to the "version 1" discs which only had a 3.9Gb capacity.
Might be worth picking up one or two of the singles and using the DVD Info program to find out who the manufacturer is (assuming the mfr. code is one that's already in the database here), but I wouldn't risk money on a spindle pack until then. After all, they might turn out to be *gag* Princos...
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 05:07 -
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 21:05 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 13:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 06:52 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 17:58
