Can anyone recommend a CVD good template for Tmpgenc ?
I also meant or would I be better off using the SVCD Template that is included with Tmpgenc and change the resolution to 352x480 and the audio to 48Khz ?
Did u try the ones in the Tools section I use one of them for burning to DVD-R, where SVCD isn't accepted standard...
rhuala -
http://www.vcdhelp.com/forum/viewtopic.php?t=130638
scroll to merkin's reply at Dec 19 14:58"speed's just a question of money. How fast can you go?" - Mad Max, 1979 -
Originally Posted by rhuala2
:P
I tried it and I was quite pleased with the results...
Thanks alot.
Kenmo -
Originally Posted by kenmo
:P
Template for effect.
By tomofthefuture in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2011, 16:04 -
AVC/H.264 Blu-Ray Template for TMPGEnc 4.0 Xpress?
By CubDukat in forum Video ConversionReplies: 8Last Post: 22nd Sep 2010, 10:52 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 07:55 -
Printing Template
By mleb33 in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 08:09 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 12:13
